Dimension Bots - Forum
Iconfx 3.x.x Cracked - Printable Version
+- Dimension Bots - Forum (https://dimensionbots.com/forum)
+-- Forum: Goodies (https://dimensionbots.com/forum/forumdisplay.php?fid=17)
+--- Forum: Cracked Tools & Programs (https://dimensionbots.com/forum/forumdisplay.php?fid=18)
+--- Thread: Iconfx 3.x.x Cracked (/showthread.php?tid=49)
Iconfx 3.x.x Cracked - Nikita - 04-10-2020
About icofx
Icofx is an award winning professional icon and cursor editor for Windows. It is an all-in-one solution for icon creation, extraction and editing. It is designed to work with Windows and Macintosh icons supporting transparency.
[Image: feat-create.svg]Create icons and cursors
Create icons for Windows and Macintosh. Support for Windows icons with resolution up to 1024x1024 with PNG compression. Convert your Macintosh icons to Windows icons and vice versa. Support for static and animated cursors. Create a favicon for your website or blog.
[Image: feat-import.svg]Import, export and extract
You can easily convert your favorite images into icons or cursors, or icons into images. Supported image formats SVG, BMP, PNG, JPG, JPG2000, TIF and GIF. You can extract icons from other files, including Windows Vista, Windows 7 and Macintosh files.
[Image: feat-editor.svg]Advanced editor
Icofx features a full blown image editor with many useful tools. You can use different brush sizes, shapes, hardness, even blending modes when painting. With more than 40 effects at your fingertips, there’s virtually no limit to the icons you can create.
[Image: feat-object.svg]Image objects
Using pre-made image object icon creation has never been easier. You can combine the image objects in layer based images using icofx. It allows you to rearrange, blend layers and change their opacity.
[Image: feat-bat.svg]Batch process files
You can easily work with multiple files using the batch processing capability of icofx (Business License). Create, convert, extract or export all your icons or cursors with just a few clicks.
[Image: feat-lib.svg]Icon libraries
Icofx gives you the possibility to create and edit icon and cursor libraries using the built in resource editor. Using the resource editor you can also change icons inside exe files.
Iconfx 3.0.0 Version with crack download
Hidden Content
You have not unlocked this post's content yet. Please reply to this thread to unlock the content.
